- Joined
- 7 Feb 2008
- Messages
- 206
- Reaction score
- 6
- Country
I will be removing a door and frame from an internal, non-load bearing wall, and blocking the opening up. A new shower will be positioned against the new wall.
Am I best to use blocks again and then get a plasterer in. Or should I use battens and plasterboard it (stud)? If I use plasterboard won't I have difficulties getting the correct wall thickness so you can't see the join against the extg plaster/wall. i.e. if the new stud is 10mmm thiner than the extg block wall then you will see the join. I hope that makes sense.
Thank you in advance.
