Boarding loft space
wombats said:
The advice you both just gave there is very appreciated. So i am looking to cross batton the joists with 2x2 or should it be 3x1 as i have seen mentioned a few times before? Also in my loft i have the insulation between the joists and just over a year ago i had an insulation company add more to it to bring it up to the required amount,but they layed it the opposite way. Will i have to re-lay this the same way so i can see the joists the fasten to?
I'd use 2x2, will flex less than 1" thick timber so will spread load better*, Fix at the same widths as the existing joists, probably end up being 400mm, maybe 450 on centres.
The insulation will have to go between the counterbattens so yes, in the same direction they are in now. You might have to cut it down width wise to fit between the 2x2. Watch for cables now :idea:
*and will be cheaper, last length of 3x1 I bought ended up costing more than the same length in 6x1. I would've ripped it myself had I known beforehand!
Thanks Deluks
Forgive me for any misunderstanding, but do i fit them directly onto the existing joists or accross the opposite way?
wombats said:
Thanks Deluks
Across, at right angle to, make a grid.
