- Joined
- 25 Jan 2019
- Messages
- 5
- Reaction score
- 0
- Country
Hi All,
I have an Ideal Classic FF280. Mostly it is very reliable, but from time to time there has been a terrible rumbling in the boiler/airing cupboard until the boiler trips out. Once reset on the little switch on the side its back to normal.
It hasn't happed very often but I've established that it only happens when the hot water is on, but the radiators are not.
When I turned the boiler thermostat down to about two and a half it stopped happening. I'd almost forgotten about it.
However recently with the colder weather I noticed that the tank takes longer to heat up especially on cold days when the heating is on for longer.
So yesterday I turned the dial up to 3 and just now its gone again.
Given it seems to be a threshold thing, is there a component that can be replaced that might be the problem (or eliminate it from the mix) ? Or even adjusted ?
I'm very happy to have a competent engineer do the work, but given its so intermittent I'd like to diagnose it as far as possible in my own time before calling someone in.
