Hello all. I have a 2 year old Worcester Bosch Greenstart 35CDi.
This morning, the heating stopped working and the boiler had an EA error on the display. After resetting, when the heating tries to come on, the boiler vibrates heavily and then errors. If the heating is not on, the hot water works ok.
I've checked the condensate pipe as best I can. I have dug it out and it's not frozen (was some water sitting in the horizontal part). I've held a hot water bottle against the condensate pipe from the inside (the boiler is 2 floors up so no access to the external top bit of pipe). made no difference.
I have a Worcester Bosch maintenance contract and they will be out tomorrow, however, I'm worried my pipes will freeze overnight. They said that the boiler would be gurgling if the condensate pipe was fronzen, and because it was vibrating (like a very stiff heavy door) and not gurgling it was likely to be the pump.
I have called round all the local companies and no-one can come out today and even if they could they don't carry parts so I'm as well waiting on Worcester coming out tomorrow.
Is there anything I can do to help the pipes not freeze, or if they do, what should I do? I think all the pipes under the floor (raised wooden floor) are lagged, but I imagine there'll be the odd exposed corner.
