I'm going to fit some extra pipe work to our CH supply/return from the boiler. I'll be adding these to the vertical run from the skirting board area (where the current pipe work runs around) to the boiler. I.e. the vertical pipes that run up the wall to the boiler. This is a bungalow and the boiler is the highest point.
So when I've fitted these T's and new pipe, the air in them will travel upwards when I open the serice valves on the boiler (where the pipes go in to it).
So will I end up with a heat exchanger full of air?? And how to I get it out? Should I incorporate a vertical coming off the new pipes with a bleed valve in it or something??
Thanks!
Thanks!
