Hi All
My boiler is currently causing no end of trouble and i am hoping someone might be able to help me out as my wife is due in two weeks and we desperatly need a warm house.
The bolier is a SIME Super 90 Mk 11 and the problem is that my boiler keeps cutting out. When turned on the boiler will heat to about 70 deg before going off and dropping to about 40 deg before turning it self back on again. This is not the problem as my boiler engineer tells that this is what is supposed to happen.
The problem is that after a few cycles of doing this the boiler hit 70 deg as normal and turns off but unfortuantly does not come back on again. I have had a boiler engineer out three times now and have so far replaced the a temp controller and the PCB but is still isn't working.
I'm not sure if this has anything to do with the problem above but we also have to turn the heating off to get the hot water working.
If anyone could point me in the right direction i would be very grateful as i don't really fancy getting a new boiler just before the Christmas and especially with a baby on the way.
P.S Someone has said that is sounds like the ignition box has gone but i'm not sure?
Thanks, Matt.
Thanks, Matt.
