Hello all
I am hoping someone might be able to offer some advice regarding this issue.
Unfortunatley in my rush this morning I was not able to photograph the boiler nor get the make/model, but can update the post with these this evening if need be.
We have a combi boiler in our flat. For a few months we have had an issue whereby the boiler loses pressure more often than I think it should. Once or twice a week we have to 'top it up' using the tap connected to the pipe.
After this had been happening a while, I noitced a pool of green-ish liquid dripping from the underside of the unit onto the kitchen worktop. At this point we called British Gas (we have a Homeserve policy). Note that the boiler was serviced when we took the policy out and no issues were found at all.
The BG engineer took everything apart, and other than a load of dead flies inside which he hoovered up (is this normal?) he found nothing wrong. He said there might be air in the system and that in time it would sort itself out. I put a piece of kitchen towel under the boiler to minotor the leak and from time to time it does get wet, but doesn;t appear to be green anymore...
That last call out was just before Christmas. This morning, I turned the thermostat up (which is located in the living room, behind the boiler), heard it kick in, then everything went off. The circuit breaker had tripped. We switched the boiler off and reset the breaker and all the plugs, oven etc worked fine. As soon as we switch the boiler on it trips.
We have called BG Homeserve again who are coming out today (my other half is at home waiting now), but given that the last engineer that came out told us it was fine (albeit for some trapped air...) I wondered if anybody here had any ideas?
Many Thanks
Darren
Many Thanks
Darren
