I've noticed recently that once the CH is nearly up to temperature, the boiler flame modulates up and down over approx a 30 second cycle. Eventually the boiler will switch off as normal once the room stat indicates its up to temperature.
Is this a sign the system is sludged up and needs a power flush?
I recently fitted a Magnaclean and dosed the system with X800 which got rid of quite a lot of iron oxide initially (slowed down now).
Ferroli Tempra 30 system boiler - S Plan
12 cast iron rads (no TRVs), 5 pressed steel rads (with TRVs).
