I have an Isofast condens boiler the problem I have is that when you turn the hot water on there is a hammering noise from the boiler. It lasts for a fair bit I usually turn the hot water off and it stops shortly after.
I'm not sure if this is related but the pressure is a bit low it was 1.3 bar now sitting at 1.4 and when I turned the blue knob below to top the pressure up it just poured out of an outlet next to it.
Not sure if that it is meant to have a cap on there as it does have a thread on it or if that it is a proper outlet.
Thanks in advance,
Stuart
Thanks in advance,
Stuart
