Boiler not staying lit??
23 Dec 2011
Ayrshire
Following on from this thread -
http://www.diynot.com/forums/plumbing/no-hot-water-alpha-ocean-240p.304836/
I cant't get the boiler to stay lit, its an alpha ocean 240P. Basically after doing the refurb of the valve I was reconnecting all the electrics, when I connected the two wires just above the ignitor switch, there was a sound like a relay/contactor dropping out and the pilot light went off (had been on throughout rest of work even with mains off)
So when I got it all buttoned up, re-pressurised etc I went to relight it, and discovered I can't. Followed all starting instruction everything to off, swith to HW only and it lights fine, then when I half let the button go the HW demand led goes out and the pilot goes to what you have normally when there's no demand, but when I let it go completely it goes out!!! :oops:
Any idea's guys??
cheers
Just had another look and it was modulating relay that I was connecting to when the pilot went off, bearing in mind the power was off?? possibly some kind of fail safe??
Its as if the coil is failing to pull in, hence only staying lit when i'm manually holding it in??
