Hi
When I run the boiler to do heating and water at the same time it sometimes runs forever and to shut it down I need to switch it off at the fuse.
When used on their own the heating comes on and off when told to by the timer and thermostat and the water comes on and off when told to by the timer and tank thermostat.
It does do the water and heating at the same time as the valve switches to mid position. So everything work OK apart from it not shutting down. Even this fault is not consistent - ie it only does it sometimes. Every time I have had BG out it has behaved itself!
My question is really about which component is at fault - I am looking at getting a Heatmiser Neo thermostat and hot water controller but if its the boiler causing the problem I would rather fix it first.
Boiler Potterton suprima 60
Contoller Potterton EP2002
Thermostat Potterton PRT100
