Boiler pressure
1 Feb 2007
My Halstead finest platinum keeps loosing pressure.
Last time the pressure dropped down to 0 i topped it up with water and it was ok for about 2 days and now is dropping back down to zero any ideas?
Bahco said:
Find the leak.
Go over your system with a toothcomb :D
Cheers that was easy found it first place i looked the pipe going into the radiator is leaking just below the nut.
what can i seal it with??
Tighten it gently first.
If no joy , you will have to drain down and put some ptfe tape around the olive or boss white :D
Cheers :P Never done owt to do with heating before so thought id check before i bodged it!! :shock:
