Hi Guys,
Having searched forum after forum and not found the answer to my problem I'm hoping that you kind folk have the answer to my problem. I have an Ideal Classic FF250 boiler about 10 years old that keeps tripping, i guess due to overheating. While this doesn't happen every day on the days that it does happen it sounds like a tank running through the house. The boiler has had the fan replaced which had been whistling. The plumber also replaced the water pump but believes that the noise is caused by sludge build up but seems reluctant to book us in for a power flush, maybe this is due to having microbore pipes but thats just my theory.
Having heard many loud clicks from the airing cupboard i checked the motorised valve earlier and it seems to me that the lever moves too freely and has no resistance. I don't know in what position the valve is stuck in, as due to its positioning i can't see the side with the lever. But I'm guessing its set to both CH and HW as when i turn the CH off and try HW only the boiler doesn't burst into life. My question is, would this faulty valve cause the boiler to trip occasionally and should i also consider changing the hot water tank stat just in case thats also faulty.
Many thanks for any advice given
