Follow along with the video below to see how to install our site as a web app on your home screen.
Note: This feature may not be available in some browsers.
Looking for a smarter way to manage your heating this winter? We’ve been testing the new Aqara Radiator Thermostat W600 to see how quiet, accurate and easy it is to use around the home. Click here read our review.
Condensing boilers should be run at the lowest setting that works effectively, which may mean the lowest setting most of the time but higher in winter. Older boilers (like yours?) it doesn't matter so much.
In fact, too low a setting on your boiler could cause the cylinder stat never to be satisfied resulting in wasted cycling which would decrease the efficiency.
