Our Saunier Duval Thermaclassic F30E is showing signs of breaking, we spent £300 on it in the last few weeks, replacing the Domestic Heat Exchange, the Flow Sensor and the Diverter Motor Head which initially resolved the issue of only getting heating, no hot water. However, she informs me its happened again this morning.
We have a friend who's a plumber and apparently these SD boilers are terrible, he pointed this out when we first moved in and suggested replacing it down the line, this was seemingly confirmed by each other engineer we had out...
When we first had issues, I did some research into Boilers, summarised in the table below;
I know nothing about boilers etc, but have shortlisted ones with similar specs to our existing boiler. I have no clue whether or not these are high end, Mid range or poor? The highlighted WB boiler is the frontrunner as to what we may go for...
Does anyone have an thoughts/suggestions/advice?
Down the line I would like to add a Nest/Tado, would the ones above play nicely with a smart stat?
