The last couple of days, our boiler has been throwing the trip. It's an 'older' boiler, a Stelrad Ideal W. Being older it's easy to diagnose and fix I hope!
I've traced the problem to the boiler, and on opening the small 'control' box found the thermostat control, a suppressor and the electrical connections to the solenoid valve, simple!
When power is applied, the valve opens briefly and there is an arc between the two solenoid connections which throw the trip.
So, whats the most likely cause of this? Although the supressor looks visually ok could it be the cause?
Cheers
Chris
Cheers
Chris
