Hi guys i'm replacing a knackered 20 year old oil boiler with a Firebird condensing one,i have a problem with the water supply i have two big 22mm copper pipes top and bottom which i'm guessing are the hot and cold return,then on the right hand side i have another two pipes one plastic and one coming out of the water pump i'm guessing are the supply pipes the lowere one is totally different tho to all the other sizes....another problem is the new boiler seems to have only three with another pipe at the bottom that looks like a different size......any help would be fab as i'm try to figure this out myself..........
WHAT IS THIS CONNECTOR ?
NEW BOILER LEFT HAND SIDE SEEMS OK 2 PIPES TOP AND BOTTOM
ITS THE RIGHT HAND SIDE BOTTOM PIPE THAT LOOKS DIFFERENT
