Hi
I turned off the water supply toady to fit a garden tap. When I turned on the water again the CH Boiler a GlowWorm 24ci was showing 0.3 bar and flashing red. So as I have done in the past I tried the refill valve but nothing happens. Water flows to the hot taps so the supply is reaching the boiler (confirmed by cracking open the fitting where it joins the boiler). The tap is turning (have tried without the extension pice added) but nothing seems to be going into the boiler.
Is this a common fault and what whould fitting a new part entail, please
Steve
Steve
