I am a couple of weeks away from moving into a new build house, on a recent visit to the property I was horrified to see that the developers had installed a gravity fed hot water system rather than a combi boiler. In fairness to them, they didn’t say it would be combi, I just assumed everything was these days.
I have accepted that I’m stuck with an inefficient system with limited hot water capacity but I’d like to improve the hot water pressure to allow for fitment of a modern tap in the kitchen (all the nice ones need 0.5bar plus), and a to have a half decent shower. It is only a small house with a single shower and I’m not after mega pressure, just something similar to a combi output will do. It is worth noting that the cold supply is mains pressure throughout, not gravity fed, so does not require boosting. The hot water cylinder is situated in an airing cupboard next to the master bedroom and there is space for a pump next to it.
As always, money is tight, so I’m looking for a cheap way to get a modest improvement. £500 would be absolute max.
As I understand it there are two options; a low pressure (approx 1bar) boost pump or to convert the hot water cylinder to being pressurised by the mains. Which is best? I do not know the make or spec of the hot water cylinder.
If I’m to go down the pump route, I see the Grundfos UPA 15 90 has had some negative comments on this forum but they seem to relate to its inability to supply large multi outlets systems. Would it be suitable for my application or is it just too weedy at an extra 0.5-0.75 bar? Can anyone recommend a (cheap) alternative? Is a low pressure pump such as this going to be too noisy? How much is it likely to cost fully installed?
If it’s the pressurised tank route, what is involved? How well does it work and what is it likely to cost? Are all tanks suitable or is it model dependent?
I’d be grateful for any help offered as I need to make a decision quickly, I have the developer breathing down my neck.
Regards, James
Regards, James
