Hi All
Is it possible to boost the pressure of the hot water system? I have gravity fed hot water and mains cold water, when we use the shower the hot water works fine until you mix in the cold water then everything goes cold, I presume the pressure of the cold water is forcing back the hot water???? Turning the cold pressure down at the main stopcock causes a problem for the gravity fed tamks to fill up. Amy suggestions would be gratefully received.
