Hi, can I install a single impeller negative pump to increase the hot water pressure to my shower and taps? The hot water is gravity fed from the cylinder on the same level. There is no cold water tank so the cold supplies are all mains fed.
negative head impellers are for a pump above the cylinder- just put a standard pump at the foot of the cylinder. as your bathroom cold should be mains, just pump the hot.
