Bosch Exxcel 1400 express washing machine
6 Jan 2012
London
I have purchased a used Bosch Exxcel 1400 express washing machine and im not sure if I connected it to the hot or cold water feed?
If it has twin water feed connections, you should find a plastic filter screen in each inlet, one is red .. hot water, the other is cold and is blue.
or alternatively a H and C pressed into the metal adjacent to each connection.
Wotan
or if it's a single feed, then it's likely to need connecting to the mains cold supply only - the washing machine will heat the water.
But if connected to the hot water, it will be difficult to do a cold wash!
Wotan
