Hi all Ive got a Bosch Exxcel dishwasher that has died over the last week.
Turn it on and whatever program you put it on the timings are all wrong. Its stopped cleaning the dishes and there is a white milky residue all over.
If i remove the silver tray bit at the bottom and the filter then that lower section has some water in it.
When i turn it on i can here the pump running ( i think its the pump) but no water runs through it.
I pulled it away from the wall, the waste water hose isnt blocked. and the water pipe is fine. But i took the small panel out where the water feeds in and it has 2 electrical connectors going onto the block where the water pipe connects too. And with this machine turned on there is no voltage going to these connectors, so i assume thats whey the water isnt being allowed in. Whether or not there is another fault which stops water coming in i dont know.
any suggestions?
any suggestions?
