- Joined
- 19 Oct 2008
- Messages
- 25
- Reaction score
- 1
- Country
Hi - our dishwasher which is about 7 years old and has never given us a problem before now seems to be a bit confused. When switched on the programme timer reads 199 minutes on the display for the Eco setting and although it will run through the programme it gets to 1 minute remaining and then just stays on 1 minute and won't end the cycle. It's not cleaning dishes properly which we suspect is something to do with whatever controls the amount of water the machine takes in. I've checked and cleaned all internal spray arms, the sump and the inlet and outlet hoses and all float valves and micro-switches seem to be ok. Both the main circulation and outlet pumps seem to be working ok. I've replaced one of the two solenoid valves which sit below the water reservoir as the original seemed to have a small burn mark indicating that it might have failed - but I did not know how to test it and for the sake of 18 quid it seemed worth a punt to just replace it. But if it was faulty putting in the new valve has not solved the problem. Could a faulty valve result in the electronic programmer getting messed up ? Yesterday I removed both trays and all the filters, spray arms and other circulation fittings in the main chamber and then ran the machine empty. The timer started at 172 minutes and then it seemed to take in a lot more water than it has been doing since the problem first arose and then it continued through a full wash cycle with no apparent problem and the timer even finished at zero. I thought that I had fixed it - but today I re-installed all the filters and spray arms etc and loaded the machine with plates and other stuff and although the programme commenced with 172 minutes on the timer the machine reverted to it's confused state and ended up showing 1 minute on the timer and the load clearly had not washed properly. The programmer has now gone back to showing 199 minutes when first switched on. Anyone any idea whats going on ? It's a good machine and I really don't want to scrap it if it can be fixed.
