Bosch series 2 dishwasher freestanding
16 Jan 2012
Uk
The machine starts up, introduces water. Within ten minutes (I have not actually yet timed it), the machine stops, showing 0:00 on the countdown timer., but no fault code. The cabinet is hot and wet. I have not done anything yet, even reset it - there is no reset button, and have yet to find a reset routine. Too late tonight to do anything - so will have to wait till tomorrow.
Any ideas, or comments, please?
Unplug for an hour will reset.
Try plugging in another socket as could be loose wire in wall outlet.
Pump is my first thought. Tip machine on side to gain access to pump.
You can wire pump to cable and plug to test. Be careful though. Pumps are cheap enough and normally easy to swap..
Failing that look for fixed price repair or buy another machine.
Bizarrely, it worked the next day. It stopped at about 10 mins from the end of the cycle, and reported E14.
Tried again and all is now fine. I suspect, with help from Google, a dodgy float valve.
Seems okay now, but just waiting for a recurrence
no its a read switch left hand side of the dishwasher
dont put mains voltage on the pump its 3 phase and low voltage
