I noticed that this machine had stopped washing properly and after testing I could see that the heater wasn't working. This doesn't interrupt the cycle, though - goes through the complete wash and stops as normal - sounds really nice from start to finish. Just doesn't heat the water and this obviously is the reason the drum is starting to smell.
I have tested the element with a meter and got a reading in ohms so that isn't open circuit, at least. But when I connect the meter to the wires that connect to the heater (after disconnecting them from the heater), to check for voltage, it always reads zero. At the time when I would expect there to be a voltage present, the minus (-) symbol does appear on the meter display, but no voltage.
I'm not sure what to check for next! Maybe something on the main board at the top of the machine? Would there be a component there that would be blown? Is power supplied to the heater through a relay that could have dirty contacts? I see a few of them on the board but I don't know. I can't find much info, so any help would be appreciated. If I could see a schematic it might help, but I can't find one.
