boss in cast iron stack
Do a search for' cast iron strap on boss with gasket ' they are expensive items £50 approx and you will also need a suitable size starett hss hole saw.
Happy plumbing :!:
If your old pipe is LCC, let the cutter do the work, don't over push, you can get away with cheap cooking oil as your cutting oil if you must.
i use a McAlpine one and never had any trouble with them.
here's a link: https://www.screwfix.com/p/mcalpine-mechanical-pipe-boss-connector-black-40mm/55722
you'll need a new or very sharp 57mm holesaw and use it on low speed in the drill, it'll go through like a hot knife through butter!
although it says you don't need to, i always put a little silicone on the fitting where it buts up against the soil pipe. 'just in case'. also, make sure it's the right way up, (it has TOP printed on it ;))
