Fitted a new water valve the other day and customer rings to say when hot water demand is closed it leaks/drips from the drain off point. More so when the bath tap has been used.
Went there today and took off drain off and checked o ring all ok and no leaks under testing over half hour.
He's just rang back this evening and said its doing it again.
It it a faulty valve?
p.s, the valve was originally changed because the previous one was leaking from the plastic valve body itself.
