britony 80se
18 Oct 2004
girlfriends boiler is getting a green flashing led and a 60 fault code,she says that in the manual it says isolation pcb faulty but looking around i think it probably says ionisation board.?
is there anything else i could check first that could cause this fault,
Fault code 60 is the ionisation PCB board fault code. It may need a couple of things checked in the combustion chamber before deciding to replace the PCB but it will need a GSR engineer to check and diagnose.
thanks,will get someone out but wanted to check that there are no other faults that i could look at first.
