Follow along with the video below to see how to install our site as a web app on your home screen.
Note: This feature may not be available in some browsers.
Looking for a smarter way to manage your heating this winter? We’ve been testing the new Aqara Radiator Thermostat W600 to see how quiet, accurate and easy it is to use around the home. Click here read our review.
Hello all , just emulsioned a bedroom wall with homebase paint and some smaal bubbles have appeaered in a small area can you tell me what could cause this please , mark
is it a smokers house? ive had this happen with nicotine before.
it has to be washed down with sugar soap first ,rinsed then painted.
if it is caused by nicotine another coat can reactivate the problem,the best way round it would be a coat of oil based eggshell as a finish or a thinned coat of undercoat followed by emulsion if you want a matt finish.
depending on the size of bubbles you may need to sand and apply fine filler first.
most likely a greasy hand mark or contaminated with something else similar.
if it is just one small area id still try the above cure but just undercoat the bubbly patch and re-emulsion that one wall
