Building Regs - how does it work?
5 Mar 2011
Sussex
Hi!
We're about to embark on some building work, basically we want to build a new dormer along the rear of the house (approx 12m long) which will create a new window and extra floor space in an existing bedroom, a larger bathroom and a new en-suite.
Our plan is for builders to build the shell of the dormer so that its watertight and then my husband will do all the internal work and knock through to the new shell himself. He will be doing all the insulation for the new dormer, electrics, plumbing etc. There is also other work within the project, moving other bedroom internal walls and insulating the other existing external walls upstairs (an existing front dormer that has very very poor insulation currently) so all the walls and ceilings will be ripped apart - its gonna get messy :D !!
My husband is confident of the practical side of all this work, but is unsure about the building regs sign off and how the process works? Could anyone explain the process please?
- Is it possible to have a chat with Building Control depts before we start the work to talk through what we are doing / see if they can pre-empt problems? (we had an informal chat with the planning office - can we do the same thing with building control?)
- Is there a good website you can recommend that breaks down a list of the stages that need signing off by building control?
- Is it purely a case of phoning building control at the appropriate points i.e after the insulation is complete, after electrics are complete etc and waiting for them to come round? Are they usually quick or could they delay the process?
- My husband plans to work his way around the upstairs working on 1 room at a time where possible. So if he started in a bedroom, did the insulation, electrics and knocked through into new dormer would we need to get building control out straight away to sign off that 1 room before we move onto the next room? Ideally we want to get each room finished to plasterboard stage before moving on and starting the next room. Or can we wait until the bedroom, bathroom and en-suite are done and then get building control out, which could be a longish wait as we don't intend to do the en-suite straight away.
Sorry this is long, I wanted to try and give all info you may need to help :-) thank you in advance.
Claire
Find out who your building inspector is and phone him up and have a chat. I found my building inspector to be very helpful. He will tell you what needs to be done and at what stage he needs to see things. If you are unsure of anything it is better to comfirm things with building control than to be told you have done it wrong and have to rip stuff out and starting again
You may also need planning permission.
Have a look at the interactive house on the planning portal website, it will give you good advice on both planning and building regulations.
http://www.planningportal.gov.uk/permission/house
Your husband may be able to do the electrical work but be careful because unless he is registered under a Part P electrical competant persons scheme he will not be able to provide the council with the correct electrical certificates at the end of the job. The council cannot complete the work until they are satisfied that the electrical installation has been Designed, Installed AND Tested to BS7671 by a competent person.
Dormers usually require some kind of structural support so you should seek advise from a structural engineer. Stuart
Thanks Stuart, yes we're able to do this under permitted development with a lawful development certificate so thats not a problem and our architect will send his structural engineer round so look at the support.:-)
Yes. Simiarly to planning, it will help them if you were to have some drawings to discuss.
You can request this from the BCO. However, as your works are up in the loft or internal alterations, some of the stages will be non-applicable.
Even though it is advisable to give BC 24-48 hours notice, you will find the majority will inspect the same day if you were to give them a call first thing that day.
The BCO can inspect different parts of the works as you proceed but they will not officially sign it off until the whole works are complete. Unless you submitted various applications, but that isn't really practical.
There are lots of links online, but a few you will find useful are...
Planning Portal (for Planning and Building Regulation advice)
Building Regulations Explanatory Booklet
http://www.communities.gov.uk/documents/planningandbuilding/pdf/explanatorybooklet.pdf
Approved Documents
http://www.planningportal.gov.uk/buildingregulations/approveddocuments/downloads
