Hi Folks,
got some queries on terminology & specifications which I'd be grateful if someone could answer/clarify for me.
"the sole plate anchor is laid above the DPC, lined up and shot fired into the concrete base" - what does SHOT FIRED mean (nail gunned??)?
Insulation in a concrete floor slab "Extruded Polyurethane Rigid Insulation" should this be Expanded Polystyrene Insulation (XEPS)?
Are "Breather paper" (timber frame construction) and "Breather membrane" (roof construction) the same thing / is there a product that can do both?
Concrete slab for a 2 x 1.5 m porch - is a 100mm C35 concrete slab with A142 mesh on 100mm insulation / DPM / 50mm sand / 150mm compacted hardcore overspecified - if so would C30 without the mesh but with the hardcore etc be adequate?
Any reason why C35 - 2:3:5 (Cement/Sand/Fine Aggregate) cannot be mixed on site?
F
F
