Is it a standard rocker switch? If so, likely you have a loose connection at a switch plate terminal. Isolate circuit, remove cover, prove circuit is dead with approved voltage tester, then look for loose connection and or terminal screws. If all seem good, it could also be your switch contacts, which will mean replacing the switch plate.
. Excuse me for being a bit thick but why, if the problem is in the switch dose the buzzing come from the cable in the the wall about 6 inch below?
