I have a Worcester 9.24 Electronic Combi and have recently changed the filling valve on the filling loop due to it leaking water into the system.
My pressure reading has always been about 1bar but noticed that it had began to rise. At the point when it went over 3bar (safety valve rateing)my first action was to check all rads for air (non found) than manualy operate the safety valve. When the pressure continued to build-up I then turned of the the supply and found that it was the fill valve.
Having fitted the valve and set the pressure back too 1bar, I now find that the system is loosing pressure and the gauge now reads 0-0.1 bar and rises to 0.3bar when the heating is on.
I have checked the safety valve outlet pipe and water is leaking from the valve.
All the rads appear to be operating properly and there are no unusual sounds from the system
Any suggestions?????
