Cable size
29 Dec 2006
Hampshire
On the copper tank in the airing cupboard is a Satchwell dial that goes from 40 to 90 (i have it set on 40 ) the cable that goes from it to the wiring box is a grey flat type 10mmx 5mm it has been there since the house was built but in order to tidy it away i need a longer cable could you tell me what size the cable should be ? thankyou
Use a round flexible cable not flat twin and earth.
Your cylinder stat should be set at 50 degrees minimum to prevent legonella.
