can any one advice on potterton combi 30 he starts and cuts
23 Nov 2010
Essex
peotterton suprima 30 he combi boiler
is starting to ignaite burner starts and then after 10 seconds cutts off
same whith hot water I have replaced new PCB bord complete diverter valve new thermistor power flushed the heat exchanger and still the same problem spoken to potterto thecnical depratment they said that
chek the condensing pipe if is bloked but is fine no blokeges on the pipe
the are apsultly useles any one can advice what alse can be done
I would find someone who has a good command of spelling and can identify the the model of your boiler if you require advise.
