Can anyone tell me what one of these is called?
15 Jun 2010
Northumberland
I have a dresser on which two of these have snapped causing the legs to break off. Can anyone tell me what they're called and suggest somewhere I can get replacements from?
Ta!!
In all fairness this is the first time it's broken in three years. I suspect someone has been dragging the dresser around instead of lifting it and moving it so more likely to be abuse than wear and tear.
This is a better view of it.
Brass plate is 3mm thick and measures 40mm in diamater. Threaded shaft is 25mm long and non-threaded shaft is 15mm long. I'm guessing it's M10 thread.
Would prefer to find a direct replacement as there's already a large hole drilled out in the centre of the leg so dowelling isn't necessarily going to be that sound.
Simple to make if you have access to a metal working machine shop.
Wotan
