I'm having a bit of a mental block with this one. I have just built a small side extension, which will house a shower, bath and basin. Quite simple.
The build is the usual, outer course brick, 100mm cavity wall full-fill insulation, then inner leaf is block.
What I am having trouble with is this - can I or can I not, sand / cement render the inside walls, then plaster them? Around the bath itself I will use either Knauf Aquapanel or HardieBacker board.
