Hi All,
I have a load of left over underfloor heating pex-al-pex pipe approx 16mm diameter that I used in my undefloor heating install in my new extension.
Can I use this to connect to my 16mm copper hot/cold supply pipes that are going to feed my new shower/toliet/basin room in my extension?
If so what fittings should I use - e.g. can I use normal pushfit with pipe inserts into the Pex pipe - will they fit? Or should I use compression?
Dont really want to buy more pipe when I have enough to use for my shower etc. plus its nice and flexible to run.
Cheers,
Cheers,
