Can you remove cement?
16 Jan 2016
Hey guys. So ive a concrete patio and i had a few big nasty cracks in it.
So i thought, for saftey and look id fill them with cement
So i did.
However
Ive now got a few sploges, some bigger then others of cement on the concrete
Anyway i could get rid. Been about 3 days so obvs its set.
I wash thinking jet wash?
Electric sander? :|
Maybe chishel or scrapper.
Any idears?
Thanks all!!!
It depends! On how thick, messy it is. Disclean will dissolve cement. Or try mechanically removing it with a cold chisel or carborundum stone.
Just knock the lumps off with a spade, scrape it clean with a wallpaper scraper and then pre wet the surface and pour a little bit of mortar acid on them (brick acid) dilute it a little and give it a scrub and wash off after 10 mins. Repeat if needed.
This may cause slight lightening of the concrete in the immediate vicinity but unlikely if its very old. Try a test patch first if your concerned about that.
THANK YOU.
will try on weekend.
Will report here for future refrence for others.
