Candy dishwasher cdi 10p75x
1 Jul 2020
Slovenia
whenever I turn on the dishwasher for the last two months, the display says in sequence h00, h01, h02...al the way to H24 and then again...
Then I have to press the button Delayed Start several times, so the display sometimes stops showing all the mentioned signs and I manage to start it. It washes the dishes ok.
I also dismantled the control panel, cleaned it but I couldn't find any flaw.
H00 , h01, h02 etc are the delayed start times
Have you tried powercycling it (turning it off and on again ) at the wall and leaving it off at least 30 secs?
Or resetting it which is done by holding down the programme selector button I believe after turning it on
Now this error is there all the time, it is impossible to stop and it is impossible to start the dish washing anymore. I dismantled the front panel and took out the control panel. Everything seems ok and the button is not pressing on the switch.
Does sound like the control panel is goosed hard to tell from here though....
No idea if this will work but it's worth a try
The problem you have is if you do find it's the control panel , it's usually works out more cost effective to buy a new dishwasher unless you can find the part second hand
