caple tap cartridge
10 Feb 2007
Cumbria
i have a caple filter tap and the tap has started dripping i have looked for a replacement cartridge with no luck they all seem to have splines at the end which mine don't have also mine has a spacer half way along.
Anyone have any advice?
undo the crosshead screw in you picture and remove the brass sleeve - I bet that there are splines under it.
you are correct there are inner splines but these arnt used the tap handle attaches to a screw which is screwed through the tap cap into the cartridge as you can see in the photo the dimple which the screw locates
sorry mate i miss read your post i see where you are coming from with the brass sleeve removal will have a look tomorrow cheers mate
