caple
9 Jul 2011
hi anyone know what fault F08 is on Caple WMI2004 built in washer is? can't find anything on net, would appreciate help, It comes up with an F08 fault when it tries to spin. The motor still spins when you set a program running but it does not speed up gradually, it does a quick burst and then stops with the fault, cheers
Sounds like a classic tacho fault on the motor . check the tacho at the end of the motor hasnt come loose also check the wiring to it
