I’ll bash on with that Harry, thanks
pulling relays, one at a time, might also help ID the leak.
I empathise with your 'lack of interest' situation, it's a 21st century attitude.Thanks Harry, i quite agree. But as i say, nobody seems to want to know. And that’s just for a diagnosis. Re. fixing the symptom, would the CCA fry the isolator? Ah also, we have another car, the Jag is not required for daily use.
Ah yeah been disconnecting neg terminal then connecting a cable from battery negative to the negative cable, in parallel with the multimeter. Then wait 20 minutes. Then disconnect the cable leaving the multimeter connected. So all the current goes through the multimeter. Have to use this “shunt” method cos the multimeter times out
I've been searching over a year for someone to remove my android head unit to check for a possible bad connection (something I don't trust myself to do due to poor eyesight & arthritis in my hand) but if I wanted an expensive replacement installed it would be a different story![]()
Only other thought is do you have a manual way into the boot, if your isolator fails in the battery disconnected position how are you getting back in to remove it?
That's true but over time the fault may also show itself in another way, I'm with you Harry in fix the original issue but I can understand why people look for a solution to allow life to move on until they revisit thingsThe other issue is - if you install this item, and it works OK, you will have much less inclination to trace the actual fault..
The Chubb Ava lock has several rotating disks, similar to an Abloy. It has no springs, and the disks are returned to their resting position when you turn the key back prior to withdrawing it. I have never seen one worn out, but they can get dirty or tarnished, and salt spray might get in. If you are using a copy key, it might perhaps be inaccurate.Thanks guys. Re opening the boot without power, it can be opened with the key. But the key is hard to turn so maybe not a good idea to use that method all the time, feels like it might wear or break something!
