Thanks.
I had some one pop over to look at insulation the loft as currently I only have 100mm of Insullation up there. He is method would be to use a spray foam. He said he would spray the foam right into the corners of the loft space (which will mean coveting the top of the cavity). I take it this is a no no then?
Also would spray the membrane on underside of the roof.
