Cavity wall insulation question
11 Jun 2016
What is the best way of checking whether the CWI is working as it should be? Many thanks
Thermal cameras are the best way. If used on the inside the cold spots will show up. When used outside you are looking for the hot spots.
Had a quick look at hiring one, does it need a specific type for what i want or do they all do roughly the same thing?
You just need a small hand held one. They just give you an image of the wall, with different colours showing the warm and cool spots on the wall. They work better when the inside temperature is a lot warmer than the external one.
Cheers
A thermal image needs interpreting, and some understanding of what the image is actually indicating and what is normal.
The different colours are relative and often of minute or small temperature changes - which may be quite normal. There will be many areas where the images show different temperature zones, for various reasons. But what you are looking for is large areas of several degree differences for no obvious reason, and not small or gradual temperature changes.
The lower the camera resolution, the less temperature zones will be shown as areas are merged into one or other colour. This can be beneficial for DIY use, as it avoids confusion and interpretation of many colours as the image shows only significant temperature changes - which is all you need to know for insulation inspection.
A higher resolution camera (as normally hired) is useful for investigating specific issues with the construction. They will show more areas of cool spots, but they can cause alarm and anxiety if the viewer does not understand the reason for such images.
The more professional imagers have better [PC] software to help interpret and analyse the image. The cheaper ones from China don't have this, so you just rely on the screen image or a jpeg.
For CWI, it's best to crank up the heating for a while on a cold afternoon and take the images from outside later when it's dark or getting dark.
Above all, you need to be careful not to discover some make believe problem that does not actuality exist, and then worry about it and how it can be remedied.
With these type of cameras, can the results be downloaded to a laptop for instance?
Professional models such as Testo or Flir save images as jpeg or tiff which can be viewed just like a normal photo image but with additional temperature data which you can be viewed in their software viewer.
Other manufacturers (eg Fluke) may use a proprietary file format which might need their own viewer.
I'm not sure about the cheap Chinese units.
But I would check that the file format does contain the additional thermal meta data, as that is useful.
A quick way is to run a thermal camera over the outside walls when it’s cold. If the insulation is doing its job you should see a fairly even heat pattern. Cold streaks or patchy areas can point to gaps or slumped insulation.
If you don’t have a camera you can hire one for a day or some energy assessors will do a quick scan for you. Indoors, cold patches on the wall or unexplained draughts can also hint that the CWI isn’t performing properly.
