Hi everyone
I hope this is the right part of the forum!
I have a 1930s build - I have an area that is now a utility room but originally was an outside toilet, an unlike the rest of the house it has a concrete floor (under the current flooring) rather than normal suspended floor like everywhere else. The corner of this room is suffering from a hard to identify damp issue.
The pointing on this side was crumbling and I have been working to replace this (slowly!) and in doing so have removed a couple of bricks to inspect the cavity.
In doing so I noticed there was debris in the cavity that I have begun to remove (but couldn't reach much). However, I was surprised that in the cavity there was basically soil and I was able to put a 4" screwdriver all the way through the ground no problem.
My question is quite dumb I am sure, but is this normal? And if I am going to clean this muck out, how far do you go?
I cannot see a DPC because the house has a plinth around it which I believe the DPC is hidden by (slate as I have found evidence of it in the garage where a brick was removed), so I intend to remove lower bricks but want to ask about the debris before I embark on this!
Cheers
Andy
Cheers
Andy
