Celtic FF 2.20 of 15 years vintage has recently developed an intermittent Pilot failure.
Symptoms: Only after prolonged DHW usage, eg 10mins shower the pilot will sometimes extinguish. After the main burner shuts down, for the next 20-30 seconds, the pilot gradually fades, so TC cools until eventually the Tev drops out. (The 105deg overheat stat is not opening.)
Has recently had new TC and 105 stat (C&M assembly complete)& Tev.
TC mv output is >spec.
Heat exchanger is clean & clear.
Pilot & gauze clean & clear.
Fan runs Hi/Lo as expected.
Next check will be to pull fan assembly, although blades appear not to be dirty, it's not easy to see if they are clogged.
Past experience with this beast have led me to expect some weird and unexpected fault,
Many thanks for all suggestions, and thanks for reading this far!
