Having HUGE problems with my central heating.
Yesterday I wanted to flush the system and add corrosion inhibitor. I opened the drain cock at the bottom of the system and it drained away quite happlily whilst filling the header tank in the loft from the cold water supply. I then added the contents of the inhibitor an allowed it to be drawn into the system.
After a couple of minutes, the flow from the drain cock stopped and the system now refuses to fill from the header tank.
Could something have been drawn into the system and caused a blockage. If so, where is this likely to be?
I've tried reverse flushing the system from a hose connected to the drain cock but all that happen is that afer a while, the water flows out of the system expansion pipe into the header tank.
Somebody please help as my wife is getting cold & angry
Brian
Brian
