Hi all
My central heating feed tank (small tank) has recently started to overflow out of the pipe shortly after the heating starts up.
I have only been in the house for a year so im not over familier with the system, but I do know its a vented system with a gas back boiler
I first suspected the ballcock/valve but this apears to be shutting off and I have set the ballcock at different levels to try and over come the problem, but it make no difference where ever it is set, infact if its set low then the water rises over the ballcock and straight out of the overflow.
There seems no water coming from the "vent pipe" to cause this
I am begining to suspect that the extra water is coming back up the feed pipe as I can see a haze in the water due to temprature differences
Can this be the case and where could this extra water coming from? And how would I go about resolving it???
thanks in advance
Al
BTW. The central heating seems to be in good working order apart from this.
thanks in advance
Al
